Paige Mary V
Cooler Master ML360R <3
I have my ML 360R installed in my C700M ,   I set it up as a push/pull on the top.  Had to take apart the top cover to put the 3 fans there. Temps while gaming in Overwatch are like between 35-45c,   and my intel I7 8700K is not really overclocked yet but running turbo 4.7ghz (power profile set to Max)  I don't see a huge benefit running higher as this is probably the only game I play that really drives my GPU (ROG STRIX GTX 1080TI)  So I am really happy  Oh and the CPU is delided and using Thermal grizzly conductonaut and kryonaut on the IHS and cooler cold plate.   Any thoughts either on the temps?
The temps before the push pull which was just a push was like between 50-58c on the CPU and 70-75c on the GPU.    The fans I am using are  the Masterfan Pro 120 Air Flow RGB.   Same with the exhaust fan in the back.
Create an account
Register a new account
Sign in
Sign In Now
