Mutaz Kojeh
Cooler Master ML240R Liquid cooler
Mutaz Kojeh    0
Hi;
I buy Cooler Master  ML240R
I install it in My PC it is good but i hear sound like : some air bubbles
the annoying pump buzzing ((pump noise))
is that bad for the pump ?
is there a way to remove the air from AIO PUMP ?
what i do return or that is normal???
THx
Mohd Noh    29
Hello
If that is air bubbles trapped in the pump , later on the air bubbles will be gone
At least 24-72H but if you still facing same issue , id like suggest you by contacting customer services for further action .
Share my Cooling :
Took 4 days > Air Bubbles disappear with full speed .
Mutaz Kojeh    0
9 hours ago, Mohd Noh said:
Hello
Share my Cooling :
Thank you
i will see and wait 4 days
Mutaz Kojeh    0
On 11/26/2018 at 6:09 AM, Mohd Noh said:
Hello
Share my Cooling :
Hi;
i wait one week the sound air bubbles will not be gone
I am worried about my new build PC
What do you suggest؟؟
ChrisM    0
Hey.
Topmounted or frontmounted?
Try to let the radiator tilt a bit.
Put some books under pc or some.
Give the air a place to settle.
Tilt the pc a little bit  it will be gone before the week
Create an account
Register a new account
Sign in
Sign In Now
