Davinci44
GPU case fan/PCI bracket combo
Davinci44    0
Most people aren't using the pci slots below the graphics card and there is a golden opportunity to increase GPU cooling by mounting a 120mm fan under the third from the top pci slot cover. I've done this externally on an H500 but I had to make an adapter plate. This could just mean tapping 4 holes on the back of a well ventilated PCIe area and letting the user mount an optional fan or the case could actually have the rear extended to allow for internal mounting - if this was done it could also allow for the fan by the IO shield to be moved farther back from large CPU coolers as well making everything flush except for the IO shield  and GPU ports which would probably have to be recessed.
