xeryus
Enforcer and Noctua NF-A20 200mm fan compatibility
xeryus    0
Hello friends,
I am reusing my old Enforcer for the new rig. And was curious if I can use these NF-A20 200mm fans at the front and top side sides of the case.
The NF-A20 has mounting holes at 154x154 or 110x180 or 170x170 mm. Would this fit the case? Thank you all.
Reznap    0
You can slightly Mod the Front Panel for the Fan to Fit, I just did mine. The door has 6 Slits and Holes to Hold the Door on. I used a Mini Demmel Saw to cut the bottom 2 off as the fan impeded them going back on. Easy Job. Door now stays on with latches on middle and top.
Edited by Reznap
