Tsetso
CM Excalibur Problem - how to lube?
Tsetso    0
I have a Cooler Master Excalibur case fan (more than 1).
It started to constantly screech (make loud and annoying noises). I want to lubricate it.
As it is a barometric ball bearing fan, is the same as a normal ball-bearing fan?
If so where to apply the lubricant and what type of lube to use? Oil? Grease?
Do I put the lubricant on the axis or I can access the ball from removing the sticker on the back of the chasis of the fan?
Any help is appreciated!
