chris
masterliquid ml120r rgb not connected correctly?
chris    0
so I have this cooler and it seems that all leds are on but I cant control them via the software. I also have the cm masterbox pro rgb case and the rgb led controller in my case to control the front fans as I don't have an rgb header. I also want to make sure my connections for the pump and fans are correct. so I only have one three pin connector on my mobo so I put the 3 pin pump to sys fan 2. the other two fans are 4 pin so I connected to cpu fan and sys fan 1. is this setup correct? thanks for any help don't want to fry new build and am new at this.
