ulaganath
CM280 FAN NOISE ON TOP TOWER MOUNT WHEN SWITCH IS IN P MODE FROM Q .
ulaganath    0
I have recently got cm 280 pro . the cooler works fine as far the temps are concerned. But the fan is generating noise under heavy load which is unbearable and even after using headphone it is hearable.
I tried raising ticket which was directed to local service center team. they agreed to replace the fans. But due to stock issues they sent some case fans which though have rubber feeding. CFM is no where closer to the stock fans which i can feel the fans pushing air at 2800 RPM.
I need the stock fan replacement is this defective for this unit or for every unit.
CM280+PRO+PUMP+NOISE.zip
