Ronald Paul
H500M 200mm aRGB fans won't spin
Ronald Paul    0
I just completed my first PC build in a Cooler Master MasterCase H500M ATX Mid-Tower. Everything works fine except for the 2 front 200mm fans. They light up but do not spin.
My build includes:
ASUS ROG STRIX X299-E GAMING LGA2066 DDR4 M.2 USB 3.1 802.11 AC WI-FI X299 ATX Motherboard
Intel Core i9-7940X Skylake X 14-Core 3.1 GHz LGA 2066 165W
ASUS ROG GeForce GTX 1080 Ti DirectX 12 STRIX-GTX1080TI-11G-GAMING 11GB 352-Bit GDDR5X HDCP Ready SLI Support Video Card
G.SKILL TridentZ RGB Series 64GB (4 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200
NZXT Kraken X72 RL-KRX72-01 High-Performance 360mm All-In-One Water/Liquid CPU Cooler
SAMSUNG 970 PRO M.2 2280 1TB PCIe Gen3. X4, NVMe 1.3 64L V-NAND 2-bit MLC Internal Solid State Drive
NZXT AC-IUSBH-M1 USB Hub
EVGA SuperNOVA 1200 P2 220-P2-1200-X1 80+ PLATINUM 1200W Fully Modular PSU
I have an ASUS Fan Extension Card but I did not end up using it. I've tried going through the bios to set the fan speeds but it's not doing anything. Any suggestions would be great, I have no clue where to start.
Edited by Ronald Paul
