Kpolupo
Will the ml 240 fit in my masterbox pro 5 rgb?
Kpolupo    0
Hello, as the title says, i'd like to know, before i buy it, if the ml240 will fit in my masterbox pro 5 rgb case, in the front of it, and leave me space for one "normal" fan (the ones that come with the case) or will i just have space for the ml240 radiator? i know that two of those fans will have to go for sure, i just wanted to know if the third one has to go too, and in that case, is it better to just keep the 3 front fans and buy the ml120 and replace the back fan instead?
Thanks
btw, i dont know if this is the right forum for this, if it isnt, then im sorry and i will move it as soon as i can
