Eric Gosselin
Defective RGB cable on my case fan???
Terence Lee    0
Nope, if its argb, it should be 3pin(the argb cable)- as intended. Argb is not rgb. They are 2 different things.
U will permanently fry the led lights in the fan if u connect that to a 4pin connector.
It was probably blocked intentionally as a precaution in case u did tried to connect that to a 4pin connector
Only the pwm cable is 4pin.
Edited by Terence Lee
