Alex
Cooler Master Elite 130 - GPU width and height
Alex    0
Hi all,
Just started my first ITX build. Despite some roadblocks, it's looking pretty good so far.
However, I found that the GPU I chose, the XFX Radeon RX 580 GTS XXX Edition, isn't able to fit inside the case. It has a stupidly huge backplate that points out at the front. It actually pushes against the ODD bay. As a result, I've had to return it.
The closest alternative I could find is the MSI AMD RX 580 ARMOR which can be found here:
https://www.amazon.co.uk/dp/B071Y7XJXN/?tag=pcp0f-21
Would the MSI AMD RX 580 ARMOR fit inside the Cooler Master Elite 130? I specifically picked it due to it not having an obnoxious backplate.
Create an account
Register a new account
Sign in
Sign In Now
