tbone127
cpu fan not spinning
tbone127    0
just got my ML120L RGB cooler today, it went together very easy but the radiator fan is not spinning. the AIO pump is working cause i'm getting
84F. it works when I turn on the system but it dies after like a min or 2.ive checked all the cables are installed right and the lights work on the fan and water block.
could it be a bad fan? I was hoping maybe someone could tell me what could be the problem. my specs Asus x470 gaming plus motherboard, Ryzen 7 2700 CPU
G.Skill Ripjaw V 16gb Asus GTX 960 4mb
thanks
Pokertoja    0
I have the same problem. For now, I connected a 4-pin fan to SYSFAN (3-pin) and my pump (3-pin) to my 4-pin CPUFAN. Works, but always works at maximum speed. The standard Intel PWM fan works well.
Anyone know what's going on?
