Peter
ML240L pump noise
Peter    0
Since installing my ML24L the pump isn’t as quite as I thought would be it’s making like a rubbing sound any one else had same problem?
what setting should it be on in bios on gigabyte Aorus bios ?
Austere    0
Hi Peter, mine started to make that sound recently. After 2-3 weeks of using it. Did you fixed it somehow? If so please share how. Thanks.
Mohd Noh    29
Hello Both :)
Owner this cooling ( forget ) maybe 1-2 days after launched
2-3 months i will cleaning this cooling
Result so far no Noise
Try unplug all the related wire 3-5 mins like that then plug in back and see how the result
Please take note > Try touch customer services via ticket for further action or assist < if still facing same issue
Hi,
Just thought I would share my experience with you. I got my ML240L RGB in August and I thought it was quiet enough but it progressively got louder until in January I decided to have a look and see if it needed re-seating or something. Upon opening my case I found that the Pump/ CPU Block had been leaking and I was very lucky it didnt blow my M2 SSD, GTX 1080Ti and/or my Motherboard. You may want to check yours. I have attached 2 pics. The heatsink covered in the coolant is on my M2 SSD and the GTX is directly below it.
I wont be fitting that again. Good Luck.
Create an account
Register a new account
Sign in
Sign In Now
