BILL JONES
USB 3.1 on front panel of Stryker
BILL JONES    0
I have an older Storm Stryker  with two USB 3.0 jacks on the front panel.  My motherboard (Asus Prime Z370-A) does NOT have a connection for that, but rather one for the newer US 3.1.
Is the pin-out the same for both connectors?  Can I plug the case cable into the MoBo port and use it with USB 3.0 devices, or will that create problems?
If so, is it possible to purchase a newer front Panel with the 3.1 jacks for my older case?
Thanks,
Bill
