Lincoln N
Master Box 5 Lite RGB Case and Remote Compatibility
Lincoln N    0
Hello!
I am fairly new to building pcs and am looking at getting the Master Box 5 Lite RGB case. After some research, I have found my motherboard does not support RGB, I also learned that instead, I can get a controller to work my RGB fans instead of an application. So I am looking to get the Cooler Master Wired RGB Controller C10L 3 and just need confirmation that the only thing I need to control my RGB fans is that controller and my motherboard compatibility will not affect it.
Thank you for your time in reading this and any responses or help would be much appreciated!
