luke johanson
Ml240L RGB not cooling
Li G Cai    2
something didnt end up. if the water is moving, then heat will be transfer. and if the fans and water are working heat should leave the rad to air.
so that leave the thermal interface. did you remove the plastic? did you apply thermal paste?
give more details, like starting temp and how fast it move up?
