mojoicus
Hyper 48 problems
mojoicus    0
Right 1st of all ive fitted the heatsink and fan no problem
But here is the problem i have an Asus AV8 Deluxe with fan connectors that are 3 pin and the connector on the Hyoer 48 is 4 pin so where do i connect oit or will i need a 4 pin to 3 pin convertor?
Please help
izzydpush    0
I'm having the same problem. I may go out and buy a fan speed controller to fix but not happy about it at all. I just emailed customer support to see what they say. The main problem is that if you have 3 pin connector on mobo you can connect it but it will only run on slowest speed. Check fine print on instruction manual or online manual. This should have come with a fan speed controller!
izzydpush    0
Thats the problem, without the 4 pin connector on the mobo its gonna run around 1200-1300, which is lowest speed.
mojoicus    0
So what am i supposed to do is there a 3 to 4 pin convertor cable cause when i boot up now i get a fan error and im told to press F1
It does load into windows tho but thats not the point it isnt working as it should
And im not buying a fan controller thats not on
Guest Mindless Moron
there are no converters for that breed of 4pin fan connector the 4th fan is for automated board speed throttling, id cut a pair of wire cutters and do the job yourself not hard, or replace the fan.
The 4pins PWM is a feature for Intel LGA775 where the MB automatically controls your fan. You could not buy a convertor because your MB doesn't have that feature to begin with.
Create an account
Register a new account
Sign in
Sign In Now
