Bruno Jose Mendoza Serrano
CM liquid cooling won't fit new CM Case
So I just bought the Cm600p Mastarcase to be able to use the Coolermaster vertical gpu bracket , a micro itx (a b250-dsh3 gigabyte MB) and the cooler master masterliquid 120. Unfortunatley I cant find  a way to fit the liquid cooling since this model has 2 fans on the cooling panel. The roof of the case can't close if the up-side fan of the liquid cooling it's installed and I cant figure out how to make this build work. Does someone has the same case/liquid cooling or knows how to help me? please :(
