David
RBG Controller - Connecting Case Sync Cable to MB
David    0
Hey Guys,
I just purchased the C700P along with a Gigabyte Aorus x299 Gaming Pro 7 MB and for the life of me I cannot work out which header the case RBG sync cable should plug into. The MB has three LED ports LED_C1 & LED_C2 for LED stips but those are 5 pin, it has the LED_IO which is for the LED lit IO shield. There doesn't seem to be any 4 pin port for syncing the MB LED to the case LEDs.... OR do I just use one of the 5 pin headers and have to work our where the V label on the sync cable needs to go? Pleae help! Thanks in advance.
MB manual is located here: https://www.gigabyte.com/au/Motherboard/X299-AORUS-Gaming-7-Pro-rev-10#support-manua
Edited by David
David    0
I raised a support ticket and the response was use the 5pin LED stip header, but ignore the 5th Pin (W) for white. The controller dosn’t need this. Not sure how that will go or what the end result will be colour wise.....
Create an account
Register a new account
Sign in
Sign In Now
