AnhTienNguyen
No BLUE color on CL pro 120 RGB fan
So i just bought 3 RGB fans + Controller for it and also a WaterCooling RGB ML240L , the WaterCooling works fine.  The main problem is 3 RGB fans doesnt have blue leds , I tried everything to test , do 0 0 255 code for blue , try to run circle color to see if there is blue , but there is none blue . And also the RGB controller application is running wrong . like if i check on red color , the fan will turn on green . Please help
Tim Kikkert    0
I have the exact same thing, I've put 3 in front. The top and the bottom just won't show a blue colour. The weird thing is that the middle one seems to be working fine. I've checked the controller itself it doesn't seem to be the problem, it really is the fans itself.   Not sure if it's a hardware or a software issue...
