julian clapham
Best place to connect PUMP - 120 LITE
Hi, i have limited headers free on my mainboard due to a fault, I plan to replace the board but all I have to work with right now is one 4 Pin CPU PWM header and a 3 PIN case fan header (which I need for my case fans)
Is it ok to Tee of my 4 pin PWM CPU header to power the pump?, I have a T joint which has a 4 pin and a 3 pin  - why on earth isnt this covered in the instructions???
