Aindriu Mac Giolla Eoin
Mesh front panel for MasterBox Lite 5 ?
Hi,
Is it possible to buy a mesh front panel for the MasterBox Lite 5 ? It could do with the same treatment that the H500P got with a fully mesh front.
I have 3 X 120mm fans sitting behind a plastic front with really bad airflow and don't want to take the front panel off and let all the dust in.
Piracha    0
I have the exact same problem and I have created a ticket as well. The case is ruining temperature and it is a big problem. My temps are not in good shape and I am avoiding heavy work like Photoshop, editing and gaming a this moment.
My message:
Quote
My setup has been running not optimally due to the poor airflow of this case. Location: Singapore Ambient temp: 33-35 degrees Idle CPU temp: 44-46 degrees 100% CPU load temp: 86-88 degrees Heard online that removing the front panel helps but it will attract dust of course. Can you offer a solution to this, please? I do have the original receipt. It is bought less than a month ago.
The reply I got from support:
Quote
Hi, Lee Zhan Wei
The MasterBox Lite 5 is built for looks, so its thermal performance will be reflected by its more closed off design.
We recommend a high air flow rear fan to improve the heat dissipation, like the MasterFan Pro 120.
http://www.coolermaster.com/cooling/case-fan/masterfan-pro-120-af/
1
Built for looks?
Pretty bad answer if you ask me.
Edited by Lee Zhan Wei
On 10/8/2018 at 10:12 AM, Lee Zhan Wei said:
My message:
Built for looks?
Sad :( to what effort is it to make a mesh panel in the same shape as a plastic one.
I understand it might be a more budget friendly option but that doesn't mean they should push the user to another product rather than offer an upgrade path.
That is after all the evolution of the personal computer in the first place.
