djliquidice
Realpower 450W issues - help please. :(
djliquidice    0
Sup everyone. I'm new to the board and i'm seeking assistance w/ my newly purchased PSU.
Model # RS-450-ACLY
Symptom:
I connected this product to my PC and it does not power up. The switch is in the on position, and the LED Fan lights up for a split second and dies.
I'm using the 24 -> 20Pin converter for my Athlon XP Motherboard and disconnected everything but the power to the motherboard and the same symptom occurs. I'm trying to seek help w/ the coolermaster
I was reading in the manual and it says to connect the 24pin AND 4pin connectors. is this required?
Evil_Acid    0
4 pin +12V you mean? this is definitely required. havnt you plugged it in yet?
djliquidice    0
ok. problem discovered. :oops: STUPID Abit Motherboard (KX7-333R) is the problem. It must not be responding to the PSU like it's expecting. I placed the PSU onto another machine w/ an AOPEN motherboard (one i'm going to switch to soon) and it works like a charm. :)
I'm so sick of this ABIT mobo.
Ron    1
To say it short: Your motherboard does not follow the current form factor.
The problem is that the MOBO is missing a -5V input.
PSU that folow the form factor standard should NOT have -5V.
Its a litle mistake made by some MOBO manufacturers in the past.
All information on form factors can be found on:
http://www.formfactors.org
