EnteMalo
MasterFan Pro 140 Air Flow RGB problem with the speed
EnteMalo    0
Hi and thank you in advance, recently i get this fan, but i have the Aerocool project 7 case, i decided to connect to the hub that the case provied, but the speed only marks  between 587 to 700 rpm i want to know how set up to 1300 (like the aerocool fans set with the hub) or higher connected directly to the MB get the same speed, and manually in turbo mod doesnt change the speed, i have a MB asus  prime b350 plus.
Thank you.
