Hello
I have just purchased a set of cm masterfan pro 120 air balance fans with controller and amd wraith max rgb cooler. My mother is non rgb is there a way to get the rgb to work on the cooler?
I downloaded the software for it and the fan and rgb appears to be a cm product. Can i plug the cooler into the fan rgb control box or is there another way or am i just not going to get rgb on it?
Cheers
Edited by mark harrison
error
