Maurilio Nose
ML120R RGB Controller Fried
Hi,
I installed the ML120R today on my computer and after a couple of ours, when I was trying to get it to work with the Software, the controller started to crash. After it crashed I unpluged it from the USB then plugged again and it worked again, after a few times I decided to give up on the Software and leave the controller running on SATA power only and I would change the led effects manually on the controller buttons.
Just when I plugged the SATA power cable to the controller, I noticed the smell. For some reason my controller fried!
Now I have no RGB or anything on my Watercooler/Fans because my motherboard does not support Addressable RGB.
I need another controller. Any thoughts?
Thanks.
