Caleb
ML240R RGB + MasterFan Pro 120 Help
Caleb    0
So I have the 240R watercooler, and it's working just fine with the controller, however I am having trouble getting the Master Fan Pro 120 (2 of them) to work with the same controller. They are just glowing a Cyan Blue color, they're spinning, but not able to be controlled at all. Just wondering if there's anybody else out there that knows, I tried to get the RGB LED Controller, the LightingControl and neither of them would work. I even have the controller plugged into the USB header on my motherboard.
Valenz68    0
I'm not sure if it's the same problem as you but on my fans I just have a small blue led that is on, can't control them too.
same ML240R btw
