Chris
Master Case 5t USB LEDs and partition LED aren't working
Chris    0
I can't figure out how to get the USB LEDs and partition LED working. I have read in other forums that you need to plug a SATA cable into the fan controller however, the fan controller does not have a port for a SATA cable. There is also a cable that is coming out of the I/O panel that looks similar to a SATA cable, but it will not fit into a SATA port on the mobo. I think this cable is the cause of the LEDs not working, but I have no idea where to plug it in. Any help would be appreciated.
Chris    0
I completely missed the SATA power connector on the fan control unit and got the LED partition working. But the USB LEDs still aren't working and I still don't know where the cable from the I/O panel is supposed to be connected. Any help would be appreciated.
