Raffy
Sync MSI MOBO to 2 CM products
Raffy    0
I bought 2 CM products which are MasterBox 500 (CM MB500)(with 3 rgb fans) see product description and a MasterLiquid 120r/ML120R , i also bought from newegg a MSI h370 gaming pro carbon that is currently being shipped.
Before i would assemble all my parts here is the specifications that i had for my rig, all are still in the box but i really need to educate myself thats why im here.
CPU: I5-8600K
MOBO: MSI h370 gaming pro carbon
COOLING: CM ML120R
RAM: Kingston HyperX 2400mhz (2x8gb)
GPU: MSI 1060 X 6G
PSU: Seasonic 620w 80+ gold (will choose CM psu apparently not available in our country, and may have but way tooo expensive
anyways the MOBO has 1 x cpu header, 1 x pump, 5 x sys fan, 1x 5050 RGB LED strip 12V connector (JRGB1), 1x WS2812B Individually Addressable RGB LED strip 5V
connector (JRAINBOW1) and 1x CORSAIR connector (JCORSAIR1)
my question is how to connect the rgb? does the case can sync in any way or another with my liquid cooling? which header should i insert the controller? can i just sync the controller into the mobo rgb header im confused atm HELP :( i havnt watched any reviews regarding argb and rgb, it may have some compatibility issue? or not? huhu .. does it sync? and could control everything in the mobo instead?
lastly , i will add the universal RGB strips for CM also but it may get me rougher to connect this rgb's
thank you so much and thank you for your time on reading my topic , i just hope somebody could address atleast bring more awareness to people who will build system with your brand
PS: The best custom modifications that a PC would have is CM more power to all CM products lover
#coolermaster
#ineedhelp
