Heracleidus
[?] Case Fans - How to intelligently control both PWM and RGB for 6 fans?
Heracleidus    0
Hi all,
I am about to start my first custom pc build, but I am already a huge fan of Cooler Master, and will include at least 10 Cooler Master components in my build.  At the moment, I need some help figuring out how to intelligently control fans that are both PWM and RGB. I'm choosing CM's MC500P Case and will replace the stock case fans with a total of 6 MasterFan Pro 140 Air Flow RGB. The motherboard will be a latest generation Asus, with which I'd like to use Aura Sync for the fan RGB as well as some other LED components such as an LED strip. The mobo has the following relevant headers: 1 x Aura Addressable Strip Header, 1 x Aura RGB Strip Header, 1 x 5-pin EXT_FAN(Extension Fan) connector, 1 x Thermal sensor connector(s), 1 x Front fan, 1 x Rear Fan, and 1 x PUMP Fan.
As mentioned, I would like to be able to control all 6 fans such that...
(1) The fan speeds are intelligently adjusted according to internal temperatures,
(2) The RGB of the fans are synced with Asus Aura, and
(3) Also still be able to connect some other RGB components to be synced to Aura as well, such as an RGB strip.
Other than that, I don't really care which headers are used (e.g. I would be fine with all 6 fans chained to one or two headers via adapters or controllers). I am willing to use whatever RGB/fan controllers or cable adapters that are necessary. I listed the relevant components here:
https://pcpartpicker.com/user/Heracleidus/saved/QrTXHx
Thanks in advance!
Heracleidus
Create an account
Register a new account
Sign in
Sign In Now
