Africanhippo
MasterFan Pro 120 RGB Not Working
Hi there.
I have just purchased 3 Master Fan Pro 120 and have connected them to my existing Cooler Master ARGB Controller that came with the new  MasterLiquid ML240R RGB AIO Cooler.
My problem is that the fans turn on and the fans light up the only problem is that they only go a light blue colour and can't be changed using either the ARGB controller or the cooler master software. I changed the fans to DC and tried both PWM the result was the same. Does anyone know how to fix this issue? I don't believe power is the issue here.
Thanks.
Caleb    0
I have the same exact issue. The software won't recognize any devices either, and my controller is plugged into my usb header and no difference. Here's my thread if it gets resolved.
