samson talboys
Not all fans are syncing in the RGB LED controller software.
Hello, I have 3 coolermaster RGB case fans and the RGB controller. I installed the software and when I go to sync up the fans, two of the fans sync together and cycle through colors but the 3rd one switches through colors at a different rate. All fans are connected to the controller on the 1st, 2nd, and 3rd slot with the 4th slot empty. Is there something on the software that I am missing, Please help I really want all of my casw fans to sync together.
Logan    0
Do you possibly have the software set on "Multilayer"? This would allow you to have a different effect for each output.
Also, check the connections between the RGB controller and each fan, especially the one that is acting different than the other. The RGB connections have four wires, one for Red, Green, and Blue, with the last one being for voltage. If you have a poor connection it may still work but have a color channel missing.
If none of that helps try switching ports on the RGB controller and see if the problem stays on the same fan or moves to another, this would indicate if it is a problem with the controller or something else.
https://www.youtube.com/watch?v=C2nzMclMLTQ
