Rene Rasmussen
MasterLiquid ML240R Fan noise
hi!
so i just build my new PC (at the writing of this post my PC is abit over a day old) and i decided to go with  MasterLiquid ML240R everything worked fine untill i decided to run the Fan optimzer in the Bios (asus motherboard)
after that my Fans for the Radiator has have been making this noise https://drive.google.com/file/d/1QaUPdXOz1U5P1mkkJxaZOmS0suyIN8p9/view?usp=sharing (this is it running at full speed so the sound can be heard better but its also there at lower speeds) i have allready written to the customer support about the issue but i would also like other people's opinion of this. are the fans busted or can i fix this somehow? i did change the options in the BIOS back to default
Necramonium    1
This is because the fans are trash, i had the same issue with one, i bought me the Corsair Air Series SP120Q Quiet Edition and all is whisper quiet now!
