I'm getting intermittent doubling of the "e" key and the "enter" key on my MK750. Every 20-30 presses the key will register twice instead of once. It only happens with those keys. If I lower the repeat rate in Windows the instances are reduced, but I don't really like the slow repeat rate for other things like Backspace.
Is this an RMA or is there some simple solution like blowing on the keyboard while wearing a tiara or something?
Tom    0
having the same issue with my 'c' key. sad to see these forums dont seem to be very active or provide any solutions. what did you end up doing mate?
xnokillzx    0
man the same thing is happening to me with my "a" "c" "e" and "u" if i remember correctly, I just stopped using the keyboard, as an mmo player you can tell how annoying that can get, I definitely think it has something to do with the keyboard we got, I got a replacement keyboard and the same thing happened, even tried it on other pc's
