BloomySkies
Cooler Master MasterFan Pro 120 Air Balance RGB- 120mm Hybrid RGB Case Fan, 3 In 1 with RGB LED Controller
BloomySkies    0
I installed the product and saw that the first two fans were turning blue but now do not display blue at all or wont sync with the fan on the third heading. using the asrock ab350m pro4. I have not tried connecting to the RGB header. The fans are new as of today. Is there any way to fix this? i feel it may be a software issue but if i delete the software it will turn off the leds
Create an account
Register a new account
Sign in
Sign In Now
