Hi,
This is my first build but the only issue I've ran into is this... I can't connect the front 3 RGB fans on this lovely Masterbox Pro 5 RGB case to my ASrock X370 Pro 4 Mobo.
I've connected RGB and fans but not getting any movement or light up effect. The back fan I connected is fine, just the front 3, plus the wires aren't even long enough to reach with cable management so it looks a mess.
Can anyone give some instruction to how you connect these front 3 fans properly? I'm using the splitter that came with the case, but not getting any power to the fans at all.
Mohd Noh    29
On 4/25/2018 at 4:31 PM, Caroline Thompson said:
Hi,
Hello
Please touching the customer services via ticket and they will assist you .
Pvtxxx    0
u need smth like this i had to buy too for my mobo mine is a asrock 970 pro 3 bit old but u had to get this for the fans to light up and do the rbg thingy . hope it helped
Alex Cooper    0
I purchased a CoolerMaster RGB Fan controller, and the LED's on my 3 front fans aren't turning on/working. It isn't letting me put in a ticket for support. so I figured I'd come here. Can ANYONE PLEASE help me. I've payed too much for this controller just for it not to work...
