Jay Norris    0
Hi. I wanna build in the Cooler Master Q300L which is a mATX case. I wonder if the Cooler Master MA620P/MA610P would fit inside that case. What other budget CPU coolers should I be looking at in case they're incompatible? The CPU will probably be a I7-8700 non K. I will be doing heavy workloads so need a good cooler.
TIA.
Mohd Noh    29
Hello
Try check official website
Clearances for Master Q300L as below
CPU Cooler    157mm
PSU                 160mm
GPU                 360mm
Clearances for MASTERAIR MA620P with RGB CONTROLLER as below
Heat Sink Dimensions    116 x 110.1 x 158.4 mm (4.6 x 4.3 x 6.2")
Clearances for MASTERAIR MA610 as below
Heat Sink Dimensions    116 x 60 x 158 mm (4.5 x 2.4 x 6.2")
Please contact customer services for more detail .
