Mke Waibel
H500P Front Fans no RGB
Mke Waibel    0
I purchased an H500P case.  I have connected the fans to 2 different RGB headers, first i had all of my RGB devices connected to a single header, using a series of splitters.   Then I attached the H500P front fans and my CPU cooler to an unused RGB header (different header from above).  The front fans work thru the fan headers, but the lighting to the RGB header doesnt.  Im assuming this should work without any controller if the board has RGB headers correct?
Any suggestions would be appreciated!!
I'm having the same problem. Everything is hooked up properly(I think) and the machine is running fine, fans are spinning, but I'm not getting any lights. I also bought the cooler master MasterLiquid Lite ML240L, and the LEDs aren't firing on that either. I ALSO bought a cooler master stand alone fan for the rear vent, and that fan lit up when I first booted up. What do you think might be going wrong?
Please help!
Create an account
Register a new account
Sign in
Sign In Now
