Nicholas Taylor
ML240L rgb controller causing startup issues
So, I just received my ml240l in the mail and started the installation. Everything went fine and I booted up with good temperatures. The problem is, however, when I turned it back off and connected the rgb controller so I could light it up (my motherboard doesn't have rgb support). When I went to turn my computer back on, nothing happened. I made sure everything was plugged in correctly (which it was) and tried it again. After unplugging the controller and some system fans it decided to boot. It booted again with the system fans back in. Once I tried it again with the controller in, it got stuck on my motherboard screen and wouldn't continue to windows. If anybody could give some insight as to why this may be happening, or how to fix it that would be very much appreciated.
Mohd Noh    29
Hello
Can you share some picture ? Did you to try reinstall or unplug the wire and see how the result ?
Own this cooling since last year ( with non RGB board + RGB LED CONTROLLER )
My suggestion would be nice if you can control the fans via RGB controller > Like Me ( Click Me )
I did try it without the controller plugged in and everything went fine (except no rgb) but then when I tried it with it back in it wouldn't get past the motherboard screen. What are you looking for pictures of, my connections/cables?
Mohd Noh    29
Yes please as below.
Pictures how you connect + related with current issue.
May i know what kind specs you have.
I have included a picture of the included rgb controller and its connection. The controller is in my hand and the power connection near the top. The connectors to my fans and pump are near the mix of cords headed into the case. My specs are as follows:
Gigabyte GA-H77M-D3H motherboard
Intel Core i5 3570K
16GB (4x4GB) DDR3 @665MHz (9-9-9-24)
4GB GeForce GTX 770
500W PSU
Mohd Noh    29
Im worried a bit about your power supply > Bronze or gold ? < maybe not enough to support or boot UP your system
My current system
z97x gaming 5 + 4690k + 750 watt  with gold certificate + asus gtx 770 2gb oc
Previously i own 500 watt with bronze certificate my system like you > sometimes boot UP and sometime failed
My suggestion
Try take off the Cooling if the system can back to normal ?
And FYI im using RGB Controller instead what you holding in the picture
Sorry late reply
Try check PSU at HERE How much wattage I need in my PSU for the PC build?
The system runs fine and boots fine with the cooler installed, as long as the rgb isn't plugged in. After checking that calculator, load wattage is listed at 477W and recommended is 577W. I think I am going to buy a new power supply and hopefully that will fix the problem
Mohd Noh    29
Hold on first
Please get an advice from our customer services might they have some solution regarding this issue .
In my mind you have to get new PSU but before that i love suggest you to touch our customer services for more detail like an advice
7 hours ago, Mohd Noh said:
Hold on first
Ok, sounds good. I have a pending ticket now. Thanks for all the speedy replys
Nikolaus    0
Hello,
I am having a very similar issue with another product.
I have been searching for a solution for hours now.
Did this ever get solved, if so how? I need help! Thanks!
