Henry ford
MasterBox 5rgb lite help
Henry ford    0
i have a masterbox 5 rgb lite and i want to know since it has 3 rgb fans what type of motherboard will i need to use the rgb without a controller i was thinking about getting the GA-AB350N-Gaming WIFI but where do i plug the rgb fans i plug them into the  RGB (RGBW) LED strip extension cable header or the CPU cooler LED strip/RGB LED strip extension cable header i want to be able to control the rgb through the program on the pc its my first time building my pc and dont want to waste money on a mobo
Edited by Henry ford
i didnt mean to tap enter
