Gushy
Cooler Master V8 GTS
Gushy    0
Hello,
i plan to buy Cooler Master V8 GTS, and Cooler Master Trooper SE Full-Tower Case, Tempered Glass, VGA Vertical Display, Carrying Handle, LED, USB 3.0 + ASUS ROG RAMPAGE VI EXTREME LGA 2066 Intel X299 SATA 6Gb/s USB 3.1 Extended ATX Intel Motherboard.
My question is will that cooler fit in that computer case ?
I read posts that cooler is too big and not fit good.
Thank you in advanced
Gushy    0
9 hours ago, Mohd Noh said:
Hello
Correct me
You meant is height or what ?
Base on what we got that Trooper support support up to 186mm height : TROOPER SE meanwhile V8 GTS only at 166.5mm
Hello, yes i mean height . But did motherboard height is calculated too ? Because this one is pretty big motherboard with big shields front and back of the mobo.
So that is my concern.
Regards:
Mohd Noh    29
Can you share some picture >> your motherboard ?
And below is picture for your reference > Stryker and Trooper
If this still make you concern i would like suggest you by contacting our customer services via ticket .
37148.c9445c863c9c706d2bd21319f27d9bef.93808d7e5e9149207eb70e2131a107cd_1600.thumb.jpg.5efe9fc9a2849ac7ad9ad145952f588b.jpg
155159.8472aa7aca0f34dbcc0c90f4931e9424.87a6cecc7cb7effb86b526051e4cf54f_1600.thumb.jpg.be2a28377c0c1500b4cd0b57e03bd505.jpg
Gushy    0
Hello
Correct me
Regards:
