Gary Lindop
Screws supplied with Master Fan Pro 140mm RGB are too big for holes in CM 690 III case
Gary Lindop    0
Just purchased the white CM 690 III case and also a full set of Master Fan Pro RGB fans (120mm and 140mm)
I have just removed the supplied single blue led front Fan and have tried to fit a 140mm RGB fan in its place but the problem is the screw holes in the case are half the diameter of the supplied screws and the stand off screws that came with the supplied Fan are too short for the new RGB fan ? This is very frustrating as i have no idea how I am going to fit these.
Has anyone else encountered this issue and if so what is the solution ??
