Renato
Seidon 240M CPU Fan pump stopped (0 RPM)
Renato    0
Hello,
I have a Seidon 240M for about 3 years now and suddenly the CPU fan stopped spinning.
Unless you have some suggestion that doesn't need to open if, I would like to know how to open to try to fix myself, but I couldn't find anyone that tried to open this exact model.
I don't see any normal screws on the top of it, I only see the many triangle screws below it, around the center of copper and I don't think that's the way to open it.
There is one gray round rubber on the top that seems to be removable, but its not so easy and I dont know if thats the way too.
By the way, I am sure it's the fan, not the motherboard or connector or any other thing.
Any help?
Thanks.
Mohd Noh    29
Hello
This is just suggestion
1. Try clean UP your Cooling
2, Try reapply back the thermal paste and Reseat ( unplug the wire )
3, Try Unscrew the radiator and shake it a bit, do you hear any water splashing around?
4, Try touching our customer services ( how to open the cooling ) and they will assist you .
By the way 3 year  is pretty long or good enough .
Renato    0
Hello and thank you for your reply,
1. My cooling is pretty clean
2. Tried that already before posting
3. No water splashing around
4. Tried, no reply so far
I am sure its the fan inside of the pump because it shows its not spinning: 0 RPM. Doesnt matter at what connector I plug it on the motherboard.
All fan connectors were tested and are working, but when I plug the pump, it doesn't spin, so can only be the pump.
Plus, like I said, it was working just fine and suddenly stopped.
Renato    0
I sent a ticket, but don't know if they will reply.
I want to open it to see if I can fix it myself, but I can't find anywhere how to open this exact model.
I found some people opening other versions like 120 or 240v, but not this one and I don't see any screw on top of ir below it that would open it.
Here are some pics of the top and below.
My best guess is that round gray thing on top of it. It seems removable, but not so easly. Maybe there is a screw under it.
Any thoughts?
Mohd Noh    29
5 minutes ago, Renato said:
Sure thing. Sent pm.
About opening it, you dont have any idea looking to the pictures?
Actually i dont have any experience with this cooling that why im suggested you to open the ticket .
Honestly 3 years is pretty good long enough maybe you have move to new cooling
Renato    0
I see.
I thought you might have some idea if I was right or wrong about removing that round gray thing.
If the support doesnt reply on a few weeks, I will try it anyway.
Thanks!
