Joao Rocha
Coolermaster H500PM Fan noise
Joao Rocha    0
Hi community;
I bought my coolermaster H500P case about 1 month.
It comes with 2x200mm fans rgb in front and 1 140mm fans at back withou rgb, then I bought more 3x140mm fans ( masterfan pro 140mm air flow rgb ) to put on the top.
- Something I notice is the fans make a lot of noise, mainly the 2 that are close to the front painel, I want to know is it happened to someone here ?
- I bought too 2 split cables 3-1 coolermaster to connect the 2 fans intake to cha_fan 1 and the 4 fans outtake to cha_fan 2 to connect the aura sync from the motherboard with all the fans, to controll speed and the rgb lighting, but sudently the AI SUIT III stoped to recognize my outtake fans, but only recognize the cpu fan (noctua NH-D15) and the 2 fans intake, have already happened to someone here ?
Here I leave a link from wetransfer to show the noise my fans make : https://we.tl/nfUyJ1Kx1A
thanks guys from the answers
VALKYRIE    11
I think sometimes the motherboard fan connectors only allow a max of 1 Ampere, if you connect with splitter too many fans to the same fan connector on the motherboard, may be that fan connector cannot support all the fans connected, may be you can check the maximum amount of current such connector can provide to  the fans attached, I dont know if this suggestion is going to sort out you issue, just an idea
  • Upvote 1
