ReloadImage
Help with cording for the RGB
ReloadImage    0
I have the case mentioned above, I just bought it now when installing all the hardware I realized that the cords for the front fans were way to short. I found the extensions for the RGB cords, but I plug in the extensions for the 3 RGB cables (4-Pin Male) and it connected into 1 RGB cable (4-Pin Male). I don't know where that 4-Pin Male RGB cable plugs in. If anyone understands my issue I would love some help!! P.S. I have the B250M PC Mate MSI motherboard if that helps!
Mohd Noh    29
Hello
May i know if this is your motherboard > B250 PC MATE is so mean you unable to install the RGB due no RGB header on your motherboard .
If really want to turn on the RGB you have to get RGB controller
Your chassis is Cooler Master MasterBox Pro 5 RGB ?
You issue same like this guy : http://community.coolermaster.com/topic/23207-cooler-master-masterbox-pro-5-rgb/?tab=comments#comment-144301
ReloadImage    0
1 hour ago, Mohd Noh said:
Hello
Could you possibly tell me which controller you would recommend me get for this specific issue.
Mohd Noh    29
Would be nice you can change it back ? because this model have 2 type
You just need this part : RGB LED CONTROLLER
This chassis coming with the RGB splitter right ?
Product Name MasterBox Pro 5 RGB
Model number MCY-B5P2-KWGN-01 / MCY-B5P2-KWGN-02 (w/RGB Controller)
