TAREK BEN MOFTAH
Cooler Master MasterBox Pro 5 RGB
i bought a new
Cooler Master MasterBox Pro 5 RGB .. but when im trying to collecting things all was good just the 3 RGB LED Fans i didn't find how to connect it to mother board (GIGABYTE GA-AB350-Gaming) the 4 pins of fans was male and the 4 pins in mother board was also male so i can't install it .. what should i do? + i didn't found a female splitter or somthing to solve it..
the picture here in cataluge shows that it should be a female spillter to both of sides ( fans + motherboard ) but it's not included with my case??
Mohd Noh    29
Hello
May i know if you get this from the chassis > The RGB Connector Splitter and 4 pin male to male adapters are included ?
yes i got it and i know that i can remove the 3 to 1 splitter cable header pin to make it trasnfer from male to female but when im trying to install it to my motherboard it's being a little small or i don't know what happend (can't be install )
Mohd Noh    29
Please refer picture as below and correct me if i am wrong
On the left is RGB connector on the right is fan connector
May i know your chassis model ?
