M50 Rider
Fan/case questions
M50 Rider    1
I bought a Masterbox Pro 5 about a month ago to go along with my MasterLiquid 240 . Due to a lack of any real directions on either the case or the cooler I had to write in for help. I got a quick answer and immediately got things sorted out . My issue now is that I want to add RGB fans but due to the fact that the radiator is mounted inside the case and the fans are mounted in pusher configuration on the other side of the mounting bracket , I need to know which series RGB fan would be most effective between the Air Flow, Air Balance or Air Pressure??  Oh and should I upgrade the rear case fan to something better while I'm at it?
        Thanks ahead of time
        Stan
Mohd Noh    29
You can check at build advise
I already made up ml 240 with Masterfan pro air blow
The lowest temperature I get is 22c and higher is 30c. and it's depends on the situation
Mohd Noh    29
Updated :
Below is some picture ya
MasterCase Pro 5 with ML 240 with MasterFan Pro RGB 120mm Air Flow
Since i am allocated my radiator on the top and my environment also not much hot so i choose the Air Flow ( refer my attached below )
What i can say here is > its depends on the situation ..  before you get any fans , you can check the higher temp + environment in your room
then you can decide which one is suitable for you chassis :)
M50 Rider    1
Thank you. My case has a flat top and isn't raised like yours The only fans I have are the two at the front blowing thru the radiator and the one at the back that evacs that case.
