Sahnya
Io pump flashing and closing randomly with Wierd noise
Sahnya    0
Hello, I installed my coolermaster Masterliquid 120 about 2 months ago. A few days ago it was making a Wierd noise and the light was flashing. I looked over my wiring to see of everything is plugged correctly. Everything seems fine. And then, the oi pump completely stopped and I had multiple CPU fan errors in bios. I checked if the settings in the bios were correct, everything seemed fine. I'm kinda clueless here. Should I go in RMA?
Edit :
GPU Asus Strix OC 6gb
Cpu i5 8600k unlocked
Motherboard asus z370p
Ssd 256gb wd blue
Hdd wd blue 3tb
Corsair vengeance 2x8gb 3000mhz
PSU evga 650 gold full modular
Case coolermaster Stryker white.
Edited by Sahnya
Forgot to put build
Mohd Noh    17
Edit :
Ssd 256gb wd blue
Hdd wd blue 3tb
Hello
Base on you story > RMA needed because before this your cooling no acting weird right ? and a few days ago your cooling starting acting weird ...
Please contact our customer services for the next step .
Create an account
Register a new account
Sign in
Sign In Now
