Rondee
Seidon 120M - Is there an AM4 Socket Upgrade Kit for it?
Rondee    0
Hi, I have a Seidon 120M and I would like to buy an AM4 Socket Upgrade Kit.
However, the only kit I found was compatible with the 120V only. So I was wondering if there is simply not an upgrade kit for the Seidon 120M.
This is the kit I found both on the CM and NCIX website: https://www.ncix.com/detail/cooler-master-amd-socket-am4-8b-140006.htm
Thanks.
Mohd Noh    29
Thanks.
Hello
Please check this link : AM4 upgrade kit
If not in the listed mean your cooling will not have or not support AM4 bracket but you can direct ask our customer services via ticket .
Rondee    0
On 2018-02-09 at 1:07 PM, Mohd Noh said:
Hello
Thanks, I contacted live support and that's the answer I got:
Hello Rondee. Unfortunately, the 120M does not have an AM4 bracket for it. It has a round shape that the 120V doesn't have.
So, unfortunately, I will have to buy a new cooler. :(
