M50 Rider
MasterLiquid 240 in a MasterBox Pro 5
Mohd Noh    29
Hello,
May i know where you wanna allocate ML 240 ?
If on the top , you need install fans to the radiator once this done you have install the radiator
Below is picture for your reference
Master Case Pro 5 with Master Liquid 240 + Masterfan Pro RGB 120x 2
20180129_233915.jpg.6eee645d350d3bc61e20e3c50139c0c7.thumb.jpg.e01b17150c928186e194bab98c93a7cc.jpg
M50 Rider    1
Hello,
The MasterBox Pro 5 has a solid top (no venting) , I bought the wrong case.  I have room to put it in the front of the case but in order to push air out, I'd have to mount the fans inside and they wouldn't be visible through the front .  Right now I  have them mounted where I'd like them but I think they are pushing air into the box.  Oh, is there an optional bracket that I'm supposed to get?
        Thanks
        Stan
M50 Rider    1
Ok, but where would I mount my hd's , it's bad enough that I had to ditch my DVD, and how would I mount the fans??  The documentation that comes with the case leaves a lot to be desired.
        Thank you
        Stan
Mohd Noh    29
Try remove the hdd cage and  install the radiator first after that you can see some space between radiator and hdd cage
M50 Rider    1
I got it,  once I removed the cage, I saw the space. Thank you for all your help.
 Cooler Master does need to step up it's game when it comes to instructions/documentation.        Thanks Again
        Stan
  • Like 1
Mohd Noh    29
        Stan
Np ... Enjoy Stan :)
